Jnewb Posted January 14, 2020 Share Posted January 14, 2020 When I try to transfer a recording to SD card, it initializes... and gets to 100% then stays there until the amp restarts. Every time. I have formatted the 2gb card on the spider amp. Any more suggestions? Quote Link to comment Share on other sites More sharing options...
CarlosBluesman Posted February 28, 2020 Share Posted February 28, 2020 Try to format it in your own pc. Don´t forget to name properly "000-Rock" Read the manual carefully. Look for it in Manual Downloads as "JM4 Advanced Guide -English(Rev. B) Abraços; Quote Link to comment Share on other sites More sharing options...
GeralynSha Posted July 23, 2021 Share Posted July 23, 2021 Not being able to read, write or move files usually means the SD card is corrupted. But the majority of the problem is you must label the SD card. Place the SD card in your PC and label it. That will fix the "Task Failed" issue 90% of the time. www.talktowendys.com Quote Link to comment Share on other sites More sharing options...
SpotSurv Posted August 4, 2024 Share Posted August 4, 2024 If the SD card cannot be read, written or if files cannot be moved it is normally because the card is corrupted. But the major of the problem is you have to come label the SD card. Insert the SD card into your PC and write on the labels that is on the side of the card. That shall solve the fix for the “Task Failed” problem in about 90% of the total cases. OR It is recommended that you try to format it on your own on your pc. It is also important to name properly, though the “000-Rock” has been done appropriately. Read the manual carefully. Search it in Manual Downloads as “JM4 Advanced Guide -English(Rev. B)” Thanks TellCampero Quote Link to comment Share on other sites More sharing options...
