Edward_odessa Posted February 1, 2020 Share Posted February 1, 2020 Hello Guys! Very interesting to know if I can use POD X3 LIVE as a MIDI Controller to catch sound from Synthesizers? Quote Link to comment Share on other sites More sharing options...
mrname Posted February 10, 2020 Share Posted February 10, 2020 I am in the same boat. I found this in another thread: "The X3 midi interface is not a full midi implementation. It does not recognize or pass THRU the note on/off commands that are critical for recording midi sequences. So you can't record midi sequences form your keyboard using your X3." I want to use my synth with Ableton Live to record MIDI tracks but I don't think it's possible with the X3 Live. I thought I could connect the MIDI OUT from my synth to the X3 Live and then use the USB connection from the X3 Live to my laptop running Ableton. I think instead I will have to connect my synth to my Midiman USB controller and then connect that directly to my laptop / Ableton. I haven't had much luck with that either though! I also wonder if Ableton is able to manage multiple USB inputs so that I will be able to use my synth and X3 Live at the same time. Quote Link to comment Share on other sites More sharing options...
mrname Posted February 10, 2020 Share Posted February 10, 2020 Running two USB cables into Ableton simultaneously seems to work fine: I connected the X3 Live to Ableton via USB as usual and also connected a synth to record MIDI via a separate USB cable (with a Midiman). Now the only problem is that I've run out of space on my desk to fit everything! Quote Link to comment Share on other sites More sharing options...
