AnnexHall Posted April 17, 2020 Share Posted April 17, 2020 I'm using a Dunlop DVP4 pedal as an expression pedal with my Stomp and am having a problem with the sweep of the pedal. I'm sure it's a setting in there, but I can't seem to figure it out. If I start at the heel, the parameter I'm controlling changes until I get to the middle of the sweep and then the parameter goes the opposite way until I reach the toe. Here's an example: I'm using the control as a volume pedal. At the heel, there is silence. As I move toward the toe, the volume increases until I get to the middle of the sweep of the pedal. The volume is now at 100%. As I continue toward the toe, the volume decreases. When it reaches the toe, the volume is again at 0. This same phenomenon occurs with every effect - wah, whammy, etc. I can't figure out what I need to make the change. Any help is greatly appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
AnnexHall Posted April 17, 2020 Author Share Posted April 17, 2020 Somehow I figured it out using the Learn function. Quote Link to comment Share on other sites More sharing options...
