Kragothius Posted April 23, 2020 Share Posted April 23, 2020 Before i explain the issue wich pisses me of. If there is any idea in the community to fix this...please let me know. Windows System: Fujitsu E Series Laptop, I5 6200U CPU, 32GB RAM, Samsung SSD System Drive, SanDisk SSD Stroage Drive (internal) Windows 10 Build 1909 Mac: MacBook pro 12§ Retina , Late 2013, Intel I5 2,6Ghz, (GB RAM, 512GB SSD, macOS Catalina 10.15.4 Amp is an Spider V120 MKii on Version 2.02 with FVB3 (v1.02.00) It does not Matter on wich of the above Computers i use the Spider V Remote App. After a few changes to a Preset the Software crashes. The stability Problems oruce since i use the FBV3. Before i could edit the Presets as much as i want. Inside Eventlog (Windows) there is an .NET Runtime Error Event ID 1026 Caused by Spider V Remote.exe EventDetails: Protokollname: Application Quelle: .NET Runtime Datum: 23.04.2020 19:53:37 Ereignis-ID: 1026 Aufgabenkategorie:Keine Ebene: Fehler Schlüsselwörter:Klassisch Benutzer: Nicht zutreffend Computer: ws-wit-015.wolfit.intern Beschreibung: Anwendung: Spider V Remote.exe Frameworkversion: v4.0.30319 Beschreibung: Der Prozess wurde aufgrund einer unbehandelten Ausnahme beendet. Ausnahmeinformationen: System.InvalidCastException bei MainApplication.WindowsCommon.Editor.SignalFlowItemEditor.ModelParamEditor.ParamControlManager.setParamValue(System.String, System.String, System.Object, Boolean) bei WindowsCommon.EngineInterface.ParamValueServer.processSetParamValue(System.String, System.String, System.Object, Boolean) bei WindowsCommon.EngineInterface.ParamValueServer.setBoolValue(System.String, System.String, Boolean, Boolean) bei EngineCLIWrapper.EngineWrapper.NativeBoolParamValueReceiver(std.basic_string<char,std::char_traits<char>,std::allocator<char> >*, std.basic_string<char,std::char_traits<char>,std::allocator<char> >*, Boolean, Boolean) bei <Module>.APIV3EngineInterface.Functions.setFloatParamValue(APIV3Engine*, std.basic_string<char,std::char_traits<char>,std::allocator<char> >*, std.basic_string<char,std::char_traits<char>,std::allocator<char> >*, Single) bei EngineCLIWrapper.EngineWrapper.setFloatParamValue(System.String, System.String, Single) bei MainApplication.WindowsCommon.Editor.SignalFlowItemEditor.ModelParamEditor.ParamControlManager.sendValuesToEngine() bei MainApplication.WindowsCommon.Editor.SignalFlowItemEditor.ModelParamEditor.ParamControlManager.mouseDraggedOnControlWithID(System.String, System.Windows.Point) bei MainApplication.WindowsCommon.Editor.SignalFlowItemEditor.ModelParamEditor.SingleSlider.onMouseMove(System.Object, System.Windows.Input.MouseEventArgs) bei System.Windows.Input.MouseEventArgs.InvokeEventHandler(System.Delegate, System.Object) bei System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate, System.Object) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(System.Object, System.Windows.RoutedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(System.Object, System.Windows.RoutedEventArgs, Boolean) bei System.Windows.UIElement.RaiseEventImpl(System.Windows.DependencyObject, System.Windows.RoutedEventArgs) bei System.Windows.UIElement.RaiseTrustedEvent(System.Windows.RoutedEventArgs) bei System.Windows.UIElement.RaiseEvent(System.Windows.RoutedEventArgs, Boolean) bei System.Windows.Input.InputManager.ProcessStagingArea() bei System.Windows.Input.InputManager.ProcessInput(System.Windows.Input.InputEventArgs) bei System.Windows.Input.InputProviderSite.ReportInput(System.Windows.Input.InputReport) bei System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr, System.Windows.Input.InputMode, Int32, System.Windows.Input.RawMouseActions, Int32, Int32, Int32) bei System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr, MS.Internal.Interop.WindowMessage, IntPtr, IntPtr, Boolean ByRef) bei System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef) bei MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef) bei MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object) bei System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32) bei System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate) bei System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32) bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr) bei MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef) bei System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame) bei System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame) bei System.Windows.Application.RunDispatcher(System.Object) bei System.Windows.Application.RunInternal(System.Windows.Window) bei System.Windows.Application.Run(System.Windows.Window) bei MainApplication.App.Main() Ereignis-XML: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name=".NET Runtime" /> <EventID Qualifiers="0">1026</EventID> <Level>2</Level> <Task>0</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2020-04-23T17:53:37.749293500Z" /> <EventRecordID>6904</EventRecordID> <Channel>Application</Channel> <Computer>ws-wit-015.wolfit.intern</Computer> <Security /> </System> <EventData> <Data>Anwendung: Spider V Remote.exe Frameworkversion: v4.0.30319 Beschreibung: Der Prozess wurde aufgrund einer unbehandelten Ausnahme beendet. Ausnahmeinformationen: System.InvalidCastException bei MainApplication.WindowsCommon.Editor.SignalFlowItemEditor.ModelParamEditor.ParamControlManager.setParamValue(System.String, System.String, System.Object, Boolean) bei WindowsCommon.EngineInterface.ParamValueServer.processSetParamValue(System.String, System.String, System.Object, Boolean) bei WindowsCommon.EngineInterface.ParamValueServer.setBoolValue(System.String, System.String, Boolean, Boolean) bei EngineCLIWrapper.EngineWrapper.NativeBoolParamValueReceiver(std.basic_string<char,std::char_traits<char>,std::allocator<char> >*, std.basic_string<char,std::char_traits<char>,std::allocator<char> >*, Boolean, Boolean) bei <Module>.APIV3EngineInterface.Functions.setFloatParamValue(APIV3Engine*, std.basic_string<char,std::char_traits<char>,std::allocator<char> >*, std.basic_string<char,std::char_traits<char>,std::allocator<char> >*, Single) bei EngineCLIWrapper.EngineWrapper.setFloatParamValue(System.String, System.String, Single) bei MainApplication.WindowsCommon.Editor.SignalFlowItemEditor.ModelParamEditor.ParamControlManager.sendValuesToEngine() bei MainApplication.WindowsCommon.Editor.SignalFlowItemEditor.ModelParamEditor.ParamControlManager.mouseDraggedOnControlWithID(System.String, System.Windows.Point) bei MainApplication.WindowsCommon.Editor.SignalFlowItemEditor.ModelParamEditor.SingleSlider.onMouseMove(System.Object, System.Windows.Input.MouseEventArgs) bei System.Windows.Input.MouseEventArgs.InvokeEventHandler(System.Delegate, System.Object) bei System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate, System.Object) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(System.Object, System.Windows.RoutedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(System.Object, System.Windows.RoutedEventArgs, Boolean) bei System.Windows.UIElement.RaiseEventImpl(System.Windows.DependencyObject, System.Windows.RoutedEventArgs) bei System.Windows.UIElement.RaiseTrustedEvent(System.Windows.RoutedEventArgs) bei System.Windows.UIElement.RaiseEvent(System.Windows.RoutedEventArgs, Boolean) bei System.Windows.Input.InputManager.ProcessStagingArea() bei System.Windows.Input.InputManager.ProcessInput(System.Windows.Input.InputEventArgs) bei System.Windows.Input.InputProviderSite.ReportInput(System.Windows.Input.InputReport) bei System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr, System.Windows.Input.InputMode, Int32, System.Windows.Input.RawMouseActions, Int32, Int32, Int32) bei System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr, MS.Internal.Interop.WindowMessage, IntPtr, IntPtr, Boolean ByRef) bei System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef) bei MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef) bei MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object) bei System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32) bei System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate) bei System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32) bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr) bei MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef) bei System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame) bei System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame) bei System.Windows.Application.RunDispatcher(System.Object) bei System.Windows.Application.RunInternal(System.Windows.Window) bei System.Windows.Application.Run(System.Windows.Window) bei MainApplication.App.Main() </Data> </EventData> </Event> Quote Link to comment Share on other sites More sharing options...
marobaraba Posted April 25, 2020 Share Posted April 25, 2020 Have same problem on my pc , when i use it on my laptop didnt have much problem barely carshed ever , its really anoying on pc like crashes lot , need help to pls some1 who know maybe lets u know Quote Link to comment Share on other sites More sharing options...
