Control Tremolo Speed with FBV?
leovinus
  • 3 weeks later...
I believe that you can. Before I purchased my FBV a short while ago, I read all the specs and apparently it can alter the same values that the "tap" blinker button does on the amp.
But that is on paper, and I've yet to try it myself. I shall experiment shortly and get back.
Hi Leovinus.
Just had a play around with the fbv. No the pedal does not alter the pulse convolutions in the tremelo.
It works on the delay, tape echo, and sweep echo to good effect. Tremelo can only be altered manually on the amp itself. (Well it does on my spider IV 75w). Would be neat if it did, but sadly no.
