cannot change default buffeer size and bit depth with latest drivers
jozinzbazin
Hello guys, I have hd500x and some problem. After installing the latest drivers I cant change the default buffer size and bit depth from its defaults (1024 and 32 bit) respectively. The onliest param I able to change is buffse suze in the lowest row of UI. Here goes the question - hiw I can overcome this problem btw I have audio from my disply in parallel with line6.
Also there is some bluescreens after the pod was plugged in (in the first two minutes). Appreciate any possible help. Thank in advance please help
https://line6.com/support/topic/55335-hd-500-and-reaper-latency-issue/?do=findComment&comment=331665
All about POD HD500/X
help and useful tips
