jcedeno4184
Pod Go bass patches ?
26 minutes ago, jcedeno4184 said:
Where i can find some Bass Patches gor Pod Go? Anyone can help me ? Thanks brothers
hey @jcedeno4184 do you mean other than the ones included with Pod Go?
following.. same question.. My kid is a bass player and I'd like to load up his PodGo with a ton of Bass-Centric PreSets. I dont suppose there is a community driven BASS snapshot we could download? Thanks in advance.
Following. Using mine primarily as a Bass unit. Hopefully we'll start getting some great Bass sounds shared here. Will post up once I've dialed in some great custom sounds.
Gonna build a Lemmy, a Jaco, a Marcus, a Jamerson and late Bootsy patches.
The fast solution is take any Guitar preset and switch the amp to a Bass amp and bingo.
I think you'll have better luck with new bass cabinet IRs than presets.  I just bought a pack from Choptones that sound fantastic (they're on sale right now too).  I wasn't too impressed with the stock bass presets either.  Take anyone of the stock bass presets and replace the cab with one of the Choptones IRs and the difference is night and day.
@jcnesbittWOW! I had no idea what Choptones was! Bought the Cliff Tribute Pod GO pack and the sounds are amazing. Does that Bass Essentials pack work seamlessly with the Pod Go? Are they .pgp files? What a cool resource, thank you!
@luca5xAwesome!  Glad you found something you like.  The IRs work differently than the presets (.pgp files).  They will be .wav files and you’ll use Pod Go Edit to import those into the Impulse Response folder.  Once there, you will use them to create or modify existing presets.  For example, take one of the stock bass presets and replace the cabinet with the Choptones IR.  You’ll be amazed at the difference.  Your Cliff tribute pack probably also came with an IR or two that you are free to use with other presets.  The Bass Essentials pack has a lot of options though and it’s only $11 right now.
@jcnesbitt IR's are loaded and this is amazing. I had a question and Choptones emailed me back almost instantly. Thank you again.
High five!
