MarkColl Posted March 10, 2021 Share Posted March 10, 2021 Helix total novice here, and having a problem with being able to work out how to save snapshots. Looked online etc and it looks like it should be so simple but I'm obviously missing something. So I set up a block in Snapshot 1, I can go into snapshot 2 and say I want to turn the blosk off, fine, I then go back to Shot 1, it's on, Shot 2 it's off. But if I want to change any of the parameters in the block say in Shot 2 but want to keep the original settings in Shot 1, whatever I change in Shot 2 then automatically changes the settings in Shot 1, so I just can't get different parameters between shots. I know it must be something relatively simple, but its driving me mad. Any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted March 11, 2021 Share Posted March 11, 2021 Whatever parameters you want the snapshot to control you have to press down the button and turn it so it gets bracketed. Once you've changed all the bracketed parameters you want to be retained in that snapshot you save it. Select the next snapshot and change them there and save. Quote Link to comment Share on other sites More sharing options...
MarkColl Posted March 11, 2021 Author Share Posted March 11, 2021 Thanks DunedinDragon, v helpful, problem sorted. I was trying to do it using HX Edit on the Mac, and have now worked how to get the parameter bracketed using that as well. Quote Link to comment Share on other sites More sharing options...
