Nalfeyn Posted March 20, 2021 Share Posted March 20, 2021 Hey folks. I recently tried to connect my pod HD500x again to my computer. I downloaded line 6 monkey and installed the drivers for the pod over monkey. I left the pod unplugged to the point the driver setup tells me to plug it in. So far so good. My pod was connected to the computer fine and monkey updated everything afterwards to the latest versions. Then I installed pod HD500x edit and out of the sudden my computer goes crazy. The computer does not recognize the pod anymore (unknown device) and keeps connection and disconnecting the device itself over the USB hub. I checked the cables, used different USB ports. Does anyone have an idea what I can try next? Quote Link to comment Share on other sites More sharing options...
hurghanico Posted March 20, 2021 Share Posted March 20, 2021 Check also the delicate USB port of the POD for damage. Sometimes it happens that it gets damaged when you accidentally hit the plug connected to it. Also try connecting the POD to a different computer. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
Nalfeyn Posted March 20, 2021 Author Share Posted March 20, 2021 I already got my USB B Type repaired on the pod because it was broken. It is recognized totally fine to the point I install the edit software. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted March 20, 2021 Share Posted March 20, 2021 (edited) 2 hours ago, Nalfeyn said: It is recognized totally fine to the point I install the edit software. I was wondering if a physical accident happened right after installing the drivers.. however, to exclude problems deriving from the computer used in particular, it would not be a bad idea to try to install everything temporarily on another one. EDIT! Oh oh oh !! I just noticed the following: You said: The computer does not recognize the pod anymore (unknown device) and keeps connection and disconnecting the device itself over the USB hub. Rule n.1 You should never connect the the POD to USB hubs, the device must be connected always to one of the main USB ports. and to USB 2.0 type only. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Edited March 20, 2021 by hurghanico Quote Link to comment Share on other sites More sharing options...
Nalfeyn Posted March 20, 2021 Author Share Posted March 20, 2021 It might be my lack of English... but I didn't connect it to a HUB. I ment usb port. Anyways. I got it working now, but have another issue right now. Whenever I open the pod hd500x edit software and he's communication with the pod I get a blue screen and windows shut down. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted March 20, 2021 Share Posted March 20, 2021 3 hours ago, Nalfeyn said: Whenever I open the pod hd500x edit software and he's communication with the pod I get a blue screen and windows shut down Try uninstalling the driver and reinstalling it manually (i.e. not via the monkey app). In the "download" section of this site there are at least 2 driver versions available for windows 10 _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
bvincentb Posted November 8, 2023 Share Posted November 8, 2023 Try to connect POD HD500x to my computer. After the first try the computer replys that the device damaged the USB connection and cannot be recognised/connected. The POD is stuck in an 'update FLASH 'message and does not work anymore. Quote Link to comment Share on other sites More sharing options...
