WienerDog Posted March 21, 2021 Share Posted March 21, 2021 I’m a relatively new user of a DT25 head and also a POD HD Pro. I’ve used the DT25 both separately and also linked to the POD HD. Right now I think I like the DT25 stand-alone better than linked, as the amp seems to have more “umph” that way. Anyway, here’s my question: the DT25 manual and some of the Line 6 videos make it seem like voicings I-IV on the amp are associated with four different feedback loop configurations. But those configurations aren’t “fixed”, are they? I used the DT Edit software to set up 8 amps of my choosing for the head. And by doing that, have I changed the feedback loop configurations? For example, for both channels A and B in the “stock” DT25, voicing III is associated with a zero negative feedback loop (like in a VOX AC30). But if I program voicing III in channel A (using DT Edit) to be a Marshall JCM800, do I still have a zero negative feedback loop for that voicing in channel A? Or have I changed that negative feedback loop to be like that in a Marshall? Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted March 22, 2021 Share Posted March 22, 2021 22 hours ago, WienerDog said: I’m a relatively new user of a DT25 head and also a POD HD Pro. I’ve used the DT25 both separately and also linked to the POD HD. Right now I think I like the DT25 stand-alone better than linked, as the amp seems to have more “umph” that way. Anyway, here’s my question: the DT25 manual and some of the Line 6 videos make it seem like voicings I-IV on the amp are associated with four different feedback loop configurations. But those configurations aren’t “fixed”, are they? I used the DT Edit software to set up 8 amps of my choosing for the head. And by doing that, have I changed the feedback loop configurations? For example, for both channels A and B in the “stock” DT25, voicing III is associated with a zero negative feedback loop (like in a VOX AC30). But if I program voicing III in channel A (using DT Edit) to be a Marshall JCM800, do I still have a zero negative feedback loop for that voicing in channel A? Or have I changed that negative feedback loop to be like that in a Marshall? If you are using the DT25 separate like a usual amp, and with the 8 amps you setup, that’s what you’ll get. It will switch to whatever you had programmed in it. If on the other hand connected to the DT25 & POD via L6 link, then in the POD you’ll have to use amp models that say eg: “AC30 pre” and the amp will switch to the appropriate settings regardless of what have programmed in the amp. Hopefully that makes sense. Jd Quote Link to comment Share on other sites More sharing options...
