Pod Pro (Rack Model) "EDITED" Light Permantly On
mick_51
Hi.
I have a Pod Pro rack model that has developed a fault. The EDITED light stays permanently on no matter how many times you push the save button. I have done the Factory Reset a couple of times, but still to no avail. I was going to use it as a backup to another Pod Pro I have, as I use them for live work. The floor controller when connected to the faulty Pod doesn't work while the Pod is in Edit mode. The only way to go through the patches is via the arrow buttons on the front panel. The patches are all intact, even if you change any of the parameters and save them. They are saved but the EDITED light stays on. Line 6 has no new updates for this model as it is quite old now. I did have the Pod XT with the Metal Gear pack installed, but found most of the patches unusable, so I gave it away. I prefer the sounds in the old Pod Pro.
Any thoughts on the problem?
Thank You
M
