Midi message not received after preset change
FERAILLE
Based on the manual, the pod go is supposed to send a Midi  message after a preset change. I would like to use that functionality to change the preset of my powercab via my pc…(the preset change on the pod will generate a preset change command on the power cab)
But…
as a first step I just connect the pod go to my iMac via USB and I was Using a midi tools to check the messages (in and out)
- device is well seen in output and input modes
- i can send a midi command to change my preset (output is ok)
But if I change the preset on the pod go no message received on the iMac
Any idea of the issue ? Something missing ? All the global settings have been checked and are on. Pod go and mac have been restarted multiple times
thank you in advance for your help.
