Changing output settings from computer?
vguerpillon
the  #1 knob on my pod hd desktop seems to be broken.
Is there a way to change the output setting from the computer ?
It is currently set on « direct » wich is fine because I mostly use it to practice at home with headphones anyway but I might need to plug it directly into an amp from time to time to jam with my friends.
thanks in d’advance,
Vincent
Unfortunately not.
You can change output setting only directly on the device through the rotary encoder n.1 when you are at page 4 of the system settings.
The encoder need to be cleaned or replaced.
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
4 hours ago, vguerpillon said:
Thanks a lot for your answer.
I will try to fix it then.
Cleaning pots and faders
