standingzero Posted December 5, 2021 Share Posted December 5, 2021 Hey all, Here's the problem: I've set one of my switches on my Morningstar MC3 (Switch C currently) to function as Footswitch 4 for my HX Stomp. This functioned perfectly while using firmware 2.9. I was able to assign FS4 (again using the MC3 to control it) to engage / disengage effects, toggle between parameters, AND to be assigned within Command Center to any function - including HotKeys. Since updating the firmware, I've lost the function of using Command Center with FS4. Some examples of what I'm encountering include: Hotkey: I've set the hotkey to spacebar to pause videos when practicing, but when I step on the MC3 (function as Footswitch 4 in Command Center) it basically has the spacebar tapping on and off consecutively at a rapid rate (regardless of whether it's set set latching or momentary). Looper: It can perform an assigned function once, after that it stops working. Again, the MC3 integrated seamlessly with Command Center functions prior to updating. Has anyone else experienced this? Any recommendations? Quote Link to comment Share on other sites More sharing options...
