bcharbour78 Posted September 19, 2022 Share Posted September 19, 2022 I have a PocketPOD that I use for live playing. I purchased a MeloAudio Midi Commander for controlling my looper pedal and wondered how I can use it to control the PocketPOD and what cable would be needed to connect the two? Quote Link to comment Share on other sites More sharing options...
liet_ Posted September 25, 2022 Share Posted September 25, 2022 Hi, PocketPOD has a USB port (mini-B), you can connect it to your computer with a standard USB A to mini-B cable (provided you have USB A ports), which will then show up as a "Line6 PocketPOD" MIDI device on your computer. If you connect your Midi Commander to your computer as well, you'll be able to cross-connect these in software. Otherwise, I'm not sure you would be able to connect the two. BR, liet_ Quote Link to comment Share on other sites More sharing options...
bcharbour78 Posted September 26, 2022 Author Share Posted September 26, 2022 OK...I want to use the Midi Commander and Pocket POD live at gigs. Sounds as if that's not possible. I had bought the Midi Commander to also use with my Boss RC-5, but the RC-5 is somewhat limited with midi control. Quote Link to comment Share on other sites More sharing options...
