Best way to incorporate noise gate pedal with 4 cable method + amp
CampNowhere
Hey everyone! I am new to the Helix and have a couple dozen presets but want to make sure I have everything set correctly.
I am using the 4 cable method along with an isp decimator noise gate in the following setup:
Guitar into guitar in of Helix
Send 1 of Helix to guitar in of amp
Send from amp to in of isp decimator
Out of isp decimator to return 2 on Helix
1/4 out on Helix to amp return
My 2 questions are:
  1. Do I need to edit every preset to have the input be Guitar instead of multi & output to 1/4 instead of multi?
  2. Where should I exactly insert the send/receive blocks in the presets I have so that it doesn’t negatively effect the amp models in the presets and that the isp decimator noise gate will work correctly?
Thank you I’d appreciate any help I can get!
