Wah position per snapshot does not appear possible
lcphill
Hi, First, I will note that I can have my wahwah effect set on/off on a per snapshot basis (that is, bypass or not-bypass, per snapshot -- in my case / in the default case, via the exp-toe-toggle). That is, I can have the wahwah off for snapshot1 and on for snapshot2.
Unfortunately, on a per snapshot basis, that is about all I can do with the wahwah pedal settings (this issue may also apply to other effect units, not just the wahwah).
I would like to be able to control, on a per snapshot basis, the (initial) position of the wahwah. Further, it would be nice if I could set the min and max values for the expression pedal on a per snapshot basis as well (it appears that min / max are only settable for the entire patch as a whole -- that is, all snapshots must adhere to the same min/max settings for the entire patch).
Final note - I tend to avoid pod-go-edit. That said, on the pod-go unit itself, I cannot find the "snapshot bypass enable" setting. I would think it should be editable on the pod-go unit itself, but I cannot seem to find it (I did find it on the pod-go edit software).
// Thank you
