USB
bright_spark
Hi experts. I’ve just upgraded from an old MacBook Pro to this years iteration, and can’t get a solid connection between computer and Helix using a USB C to USB dongle. Is there a cable that’s recommended to give a direct connection from Helix USB B output into standard USB C on my MacBook? Any links would be much appreciated!
Apple makes a USB-C to USB adapter. I've had good luck with Apple adapters in the past, so this might be worth a shot. You may even be able to take your Helix and MacBook Pro to an Apple store, and if they have the adapter in stock, try it to see if it works.
FWIW I needed to go from a Thunderbolt 3 port on my computer to a peripheral with TB2. I was told it likely would not work unless I bought the $100+ Startec adapter, but the Apple adapter worked just fine and was less than half the price. Good luck!
