'default' Position For Expression Pedal Controlled Values
jbjhjm
Hi!
I'm having a hard time to control how loud one expression pedal based volume fx should be when I load that preset.
Somewhere in the forum archive I found this:
http://uk.line6.com/supportarchivenew/thread/89860?tstart=4
it says there's no default value it just uses the last position it remembers.
But this doesn't seem to work for me.
What I tried:
- Setting expression pedal to 0, switch preset. Result: 100% loudness.
- Sending the expression CC command manually, then switch to preset. Result: 100% loudness.
- Switch to preset, then immediately fire a manual CC command. Result: 100% loudness.
- Switch to preset, send a manual CC command a second later. Result: Works.
But let the preset run at 100% loudness for a second is no option for me!
How on earth is this supposed to work?! Getting tired of trying and trying... <_<
