dzaustin74 Posted November 25, 2023 Share Posted November 25, 2023 Since updating to 2.0, my POD Go only displays presets C and D. Nothing I've tried gets me back to seeing all four (A, B, C, and D) at one time. If I tap any of the six buttons on the left side of the panel (up/down or any A-D), or rotate the View/Action button, I see all four presets for about one second, then it reverts to only two. I did a factory reset and reinstalled the firmware and update. Also, in the space where presets A and B should be, are the elements (I know that's the wrong term, but I don't know what it is called in Line 6 parlance) of the particular feature the red arrow is selecting (by rotating the View/Save dial). For example, if I've selected the Amplifier, then Drive, Bass, Mid, Treble, and Presence are seen (again, where A and B should be). The Drive number rapidly flashes back and forth by units of 0.1, e.g., 4.5 to 4.6, then to 4.5, 4.6, 4.5, 4.6, etc. Regardless of what the red arrow is pointing at (Distortion, Reverb, Delay, etc.) the first setting (farthest to the left) does this 0.1 unit flashing. And when I double click on a preset, it takes a little longer than typical, but loads the preset, and I get a pop-up saying "Failed to load preset. Timeout waiting for a response from device (code -8212)." These don't sound like software issues, but I'm hoping somebody can prove me wrong! Thanks. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted November 27, 2023 Share Posted November 27, 2023 It seems to me that you likely have some software corruption. I recommend: 1. you back up your patches & do a reset back to factory again. 2. If the above doesn't resolve the issue then I recommend you re-install v2.0 & factory reset after the re-installation. 3. If none of this works you should then raise a ticket with Line 6 customer support. Quote Link to comment Share on other sites More sharing options...
