Expression Pedal with Two Button Footswitch (via MIDI)
HilpertonBoy
This is interesting.  In the (English) manual on Page 31, in the section 'Controlling HX One Parameters via MIDI', in the table 'Exp Pedal & Footswitch Emulation - MIDI CC'. indicates that if you have a MIDI expression pedal, CC3 will work as an expression message as:
  • CC3 Value 0-127 - 'Emulates Expression Pedal (when Settings > Pedal Jack is set to “ExpFS4”)
Note that this suggests that the MIDI expression will only work if the Pedal Jack is set EXPFS4.
I have found that even with the Pedal Jack set to 'FS3/4' the MIDI expression still works.
The upshot of this is that we can use a two-button switch (on FS3 and FS4) and an expression via MIDI at the same time.
How cool is that?
  • 3 months later...
