HX Stomp - MIDI send when choosing a preset?
Evil_Orco
Hey there,
I am a newbie struggling with the HX Stomp Midi controls.
In my setting I want the hx stomp to switch my amp's channels when I select a preset on the stomp.
I already managed to assign the relevant midi cc commands to the footswitches. However, the normal hx's function would be that I have to press the footswitch when the preset is already active.
However, I would like to customize presets that can be selected with a single hit on the footswitch including switching channels on my amp.
Is there a way to send a midi command when a PRESET ist selected (and not when a snapshot or a FS "within" the preset is activated)?
I am looking forward to you replies. Maybe there is a simple way I just have not found yet...
Thank you!
Edit:
I was able to send the right midi commands by configuring the inserts in the command Center.
Each preset can now change my amp’s channels.
unfortunately, while the amp reacts immediately there is a noticeable gap until the right sound is properly dialed in. I assume it is an Hx stomp issue.
does anybody have any experience with that problem?
Edited by Evil_Orco
Issue partly solved
