Flextone II HD: Left Channel Dropping Out Intermitently [ SOLVED ]
My LEFT SPK CHANNEL was dropping out more often than not & thought i had a CAP or TRANS issue, but found the LIVE/STUDIO toggle switch in the back was simply oxidized/dirty. Spent about an hour inducing/resolving the problem to narrow down root cause & solved it with Electronic Contact Spray (go easy with it yo!)
The front knobs were mentioned several times, but didn't come across this issue/root cause so figured I'd drop a note on quite the serious problem with an equally simple solution.
  • Picked up one of these units a while back for its stereo capability and on the first go at it, the Left Channel was "hotter than Georgia pavment" then slowly faded out to about 50% so stuffed it off in a room for about a year & now finally getting back around to loose ends.
  • Parsed boards and excluding component failure, the 'pots' were often brought up as root cause to volume problems. Given they are analog front-ends to digital functions, 'scratchy pots' can cause wild swings in the values they induce to the logic boards.
  • My particular issue didn't really match, so sat with the unit for about an hour to create the problem, solve it, create the problem.
  • Triage:
    • Powered down amp and swapped the speaker cable between LEFT & RIGHT and adjusting the front knobs and changed 'channels', FX, cabs, etc. - wasn't telling me much
      • Moved on from A/B comparisons and stuck with the LEFT problem child channel
    • Originally thought it could be week PCB traces or solder joints since it worked for about 3min when I first powered it up.
    • Toggled the Speaker Ohms toggle from 4-8-16 several times - no help.
    • Since the channel came back to life intermittently, went ahead and sent the XLR outs to a mixer to monitor with headphones.
      • LEFT still had issue
    • Swapped LEFT/RIGHT XLRs & problem followed the LEFT XLR cable.
      • Deduced issue was NOT with the POWER AMP ( which was my original thought )
    • Ran TRS from FX SEND to RET
      • no change
    • Went ahead and pulled the head out of the chassis and found duplicate boards in use for LEFT/RIGHT paths, so
      • swapped the to I/O ribbons off the MAIN PCB
      • Issue STILL on the LEFT CHANNEL
      • swapped the I/O ribbons to their original orientation.
    • Before diving in to look at components, sat with it for about 40m recreating/fixing the issue
      • I noticed that if I MAX'd each knob for full volume, the LEFT channel would be inclined to eventually come back to full strength.
      • Was still suspecting the POTS, but it really didn't seem logical that controls that impact BOTH channels could take out only one channel - was musing perhaps a POT leg was shorting or creating some other ground issue.
    • The root cause was found when taking another look at the back & found the LIVE/STUDIO toggle switch.
      • When I touched it, the familiar scratching sound ushered forth and after jiggling it around delicately I could kill & resuscitate the LEFT CHANNEL.
      • I dropped the MIDI/XLR board out and gave it a quick spray of Electronic Contact Spray, worked in for about 30s, reinstalled and SOLVED.
Hope either the diags or the root cause / solution helps someone else!
