MAKory Posted January 8, 2024 Share Posted January 8, 2024 As a relatively new owner and after spending a lot of time R'ing T F M, I set about to create my first preset & snapshots. I started by copying the factory preset 22D Shining Star, did some tweaks, and then created 4 snapshots. Things seemed to be working fine until I played around with the Input Gate settings (although I can't be sure that's what caused the problem) For some bizarre reason now, all 4 snapshots work correctly only after first powering up the Pod Go. But as soon as I switch to any other preset and then back to mine, Snapshots 1,2 & 4 are dead silent - only 3 works as it did before. I can find nothing in the snapshots themselves that look out of place, but the fact that it always works correctly after turning the PG off and then back on seems to indicate a bug. Any suggestions on how to fix without starting from scratch? (Unfortunately, the export I had saved has the same bug.) Also, there's what appears to be another relatively minor display bug with the Input Block in Pod Go Edit. When you select any preset and switch to the Input Block, the parameters in the Edit Panel are "lit up" regardless if the Input Gate is on or off (the same as other blocks are when they are enabled). But when you switch to another snapshot, the parameters are all dimmed (like other blocks when they are bypassed), and stay that way regardless if the gate is on or off. Quote Link to comment Share on other sites More sharing options...
MAKory Posted January 8, 2024 Author Share Posted January 8, 2024 I called Line6 support and went through troubleshooting with Josh. The problem was due to the fact that the Volume pedal block position was set to 0. I don't recall touching that parameter, and even if I did, it doesn't explain two things: 1) Why snapshot 3 continued to work, even though the position was 0 for all 4 snapshots, and 2) Why the preset worked after powering up the Pod Go. I sent a backup to Josh and he's going to try to figure out what's going on. As far as the dimmed display of the input block parameters in Pod Go Edit, Josh confirmed the issue and that those parameters should never dim, and said it's likely a bug. Quote Link to comment Share on other sites More sharing options...
