aribaboss Posted February 4 Share Posted February 4 Recently upgraded to an SM7B and it seems to work just fine with the UX2 as long as I have a pre-amp. My problem, however, is how it's causing a lot of static/white noise when the pre-amp is directly plugged into the UX2. There is no noise whatsoever when it's plugged directly into the mic instead. Does anyone know if there's a solution for this? Edit: Figured I might need an additional XLR cable so the Dynamite isn't plugged directly into the interface. Will update once I've tested Edit 2: Nope, made the static noise almost worse. Fun. Quote Link to comment Share on other sites More sharing options...
