Floor VS Rack MIDI/EXT Tap Tempo problem
isolated1523
With my Floor, I could successfully send MIDI notes from my computer to change tap tempo of the unit. At the same time, the Floor would forward/send those taps through the EXT AMP out to sync the delays in my FOH mixer (matches vocal delays to BPM).
I just bought/updated/configured a Rack unit, and it still receives MIDI Tempo taps from my laptop without issue. Also, physically tapping the Control tap button will send the Tempo through the EXT AMP out and control my FOH mixer. However, the Rack will NOT do this simultaneously as the Floor did.
Is this a bug? Or a limitation of the Control board?
****Edit -- this seems to be an issue with the newest update; as neither the Rack or my Floor are passing the taps through after update.
Edited by isolated1523
More info
