cfarris87 Posted June 27, 2024 Share Posted June 27, 2024 Hey guys! Been a huge Mule/Haynes fan for years. I wanted to create something that could be used for their full catalog as all the presets I have sampled have just been well... not that great. I'd love your thoughts on this. Let me know what you love and hate! I was a little torn between the Solo Lead Crunch and the Solo Lead OD, ended up settling on the OD with the gain on 2.5. Despite Mule's in your face attitude, Warren plays very low gain in most cases. The sweet spot here is between 7-8.5 on the guitar volume and you can crank it to 10 when you really want it. I can't express how important this is for some tasty Warren tones. Also note, Warren mostly uses the bridge position for rhythm and the neck position for most of his lead stuff. Made this with an SG with Bare Knuckle Mule (PAF style) pickups. Pedal list and function: Low Cut: exactly what it says. He doesn't use it much, but it stays on his board for certain uses. Auto Wah: As we all know, we don't have a great option for this. I tried the mutant as well but this is about as close as I can get for those "Mighty High" sounds. Still wasn't able to really dial it in. Best on around 8 guitar vol. It responds better when you crank up the vol but doesn't sound great with the extra gain. Delay: Well... delay. Nothing fancy. Warren uses a simple analog. Octave: Nothing crazy here either. Just an octave down with enough mix to come through. Rotosphere: Did I few things here which turned out pretty well I think. Tried out the Sadites trick of running two with slightly different speeds on the horn and woofer. I also linked the cab in with the switch to disable the cab when the Roto is activated and added a Low/High shelf since the only cuts were in the cab itself. I added an EQ after the Roto to tame some of the undesirable harshness that comes without it. This also responds and sounds much better/accurate at lower guitar volumes as well. Around 3-5. High&Mighty: Just a high gain Minotaur with the tone rolled way back for some of the more heavy tones like you'd find on High and Mighty. I love the Minotaur for this since it really keeps our definition and doesn't get over-saturated. Klon: Low gain Minotaur just for some tone shaping and tightness. Just Enough: This is something I've been adding to most of my presets. 10-Band EQ with the gain cranked and some eq shaping that acts as a natural overdrive. I've loved this set-up on everything. Especially Fender model amps in a more Country rig. I usually pair it with a volume cut after the cab but didn't feel it was needed here. Feel free to throw it in some of your own presets! Wah: I haven't found a wah on the Helix that I've been a fan of. But the Throaty seems close enough to a Bad Horsie type wah. Reverb: A little plate to fall into the mix. If you're really going for a Warren tone, use very sparingly. But I personally prefer a wetter verb. Cab: Greenback 25 w/57 Mule.hlx 2 Link to comment Share on other sites More sharing options...
