kontrol3 Posted August 9, 2024 Share Posted August 9, 2024 I use a splitter on the dl4mkii expression. one side 5 is a foot switch for accessing (classic) looper mode. the other 6 is for an expression pedal controlling mix (looper level). Works fine — except i think it’s weird the loop keeps playing when switched out of looper mode. Question: today i tried the 1-switch looper. Something is causing it not to go into record. the 5 footswitch, according to the global settings in the manual only for classic looper, ok, but why won’t the 1-switch looper work after setting Tap to 1-switch looper? thanks Quote Link to comment Share on other sites More sharing options...
