Nothing Else Matters preset for HX Stomp
Uberjohn
I'm astonished that there's not a publicly available HX Stomp preset for the clean intro and outro on Nothing Else Matters.  I'll try to upload a decent one later today.   In order to build the preset I did some research, and discovered that the amp used by Metallica was a Boss Jazz Chorus, which has a Boss CE-1 chorus built in.  Eureka!  Also it helps if you can crank up the treble on your neck humbucker.  The active pickups used by the band are very bright.  I have a 2015 Les Paul Classic with a built in boost/buffer circuit that eliminates tone suck caused by distributed capacitance in the instrument cable, which really brightens up the 57 Classic pickups.  They are so bright that I put metal covers on the pickups to reduce the treble a bit.  You can also boost the treble on the amp model or add an EQ block if needed.
  • 3 weeks later...
I updated a new version of this patch on 1/22/2025.  It has a 10 band EQ instead of a compression block.  Enable the EQ to add treble to the tone.  You can try a little less boost at 8 and 16 kHz to tame too much sizzle.
Now if only I could remove the earlier patch to avoid confusion...
