lillehl Posted March 17, 2025 Share Posted March 17, 2025 I currently use an HX FX in a hybrid DAW setup. Guitar is plugged into the input of the HX stomp. Headphones are plugged into the headphone out. HX Stomp preset is set up with USB 5/6 as inputs. I have one track in my DAW with USB In 7/8 (dry DI) as input and USB Out 5/6. I have another track with USB In 1/2 as inputs and USB Out 1/2 as outputs. This lets me apply effects that are not in the HX stomp, either before (in series) or after (in parallel) the HX Stomp's processing. I can also use tools in the DAW to analyse the input signal and modulate parameters on the HX Stomp via MIDI over USB. As far as I can read from the POD Go manual, this would work exactly the same on the standard POD Go. But - what about the Wireless version? 1) Can I use the wireless system and have a functioning dry signal from that wireless system on USB In 3/4? 2) Can I have the POD Go input set to USB 3/4 while the wireless unit is still connected and transmitting the dry signal to USB in 3/4? Thanks so much! Quote Link to comment Share on other sites More sharing options...
