Connecting An Hd500 And X3 Live
matthewfinnish
Hello Guys,
I have patches on both my boards (X3 live and HD500)  that I use on different songs from different albums, all of which I have to re-create live. Is there a way of connecting the two boards together so that if I need a patch on the X3 it will run through the HD500 to the amp and FoH or vice versa? (HD500 through X3 Live)
For example: Connect HD500 (or X3) to FoH via xlr; connect mono output from HD500 (or X3) to amp; link the two boards together so that if I need a patch from X3, the signal goes into HD500 and then out to FoH and amp.
Thanks
MatFin
You could connect the hd500 fx send to the x3 input with no return, and put the fx loop block set to one of fs 1-4, first block in every patch. That way, you can just hit the fs for the loop to send it out to the x3 without ever hitting any of the hd500 amps or effects. Then use a mixer, or di for both units to the board.
