TrippleDke Posted June 27, 2025 Share Posted June 27, 2025 Hi, I'm working on downsizing my pedalboard and recently picked up an HX Effects. When I run my OD Orange through my Marshall, the ISP Decimator G-string II works perfectly in 4CM. However, I tried the Horizon Gate on the HX doesn't quite deliver the same results. I'm curious if someone has setup the ISP with the HX Effects. I would like to use the ISP as my gate (always on) and also use the 4CM on the HX. I’m having trouble understanding the correct routing. Should I be using the second effects loop on the HX as well? Any help would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
