RitterSport Posted December 10, 2025 Share Posted December 10, 2025 The Pod Express forum is grayed out for new topics. Maybe a moderator can move this? Any reason the Pod Express forum doesn't work? Or, maybe leave it here, since there have been other complaints about that forum not working. Anyway, I just got the Pod Express Bass and I'm having a blast playing with it -- it will definitely join my live rig shortly. I'm hoping the folks here are pretty familiar with it and can help me with some questions: Is there any way to stop the effects from resetting every time I start up the machine? For example, in the Mutant synth, I will probably never want it in Band Pass mode, only Low Pass. So, I change it to Low Pass in the app, and that's great, but if I leave and come back, it's set to band pass again. Other than Studio and Punch, the rest of the built-in Amps are pretty distorted, like they have a distortion effect on. I can reduce the gain the get rid of some of that, but then when I go back to that amp, I have to adjust the gain again. Am I just doing something wrong? In the Android app, let's say I'm on preset 12 and I start fiddling with the sound, and I find another great sound, but I don't want to save it over preset 12, I want to put it on a new preset. Is there any way to do that from within the app, or do I have to press down the Amp knob, rotate it somewhere, and press again to save? Is there a difference between the Channel Volume setting and the little thumb wheel, when thumb wheel is set to control all volumes? That is, are they independent volume controls? When setting the Gain, Bass, etc., is there a technique to use where I can adjust that without also modifying the effect on that knob when I let go of the Alt key? Is the noise gate part of a preset? When does it get reset? Has anyone put together a cheat sheet that has all the button shortcuts? For example, Alt-Tap-Comp to set the gate level, etc.? Thanks! I may have more questions -- I've only had this since Saturday... Quote Link to comment Share on other sites More sharing options...
RitterSport Posted December 10, 2025 Author Share Posted December 10, 2025 I had Claude (Anthropic's LLM) look at the manual and it pulled out these shortcuts: POD Express Bass - Key Combination Shortcuts Amp Parameter Editing Hold ALT + Turn COMP knob → Adjust amp GAIN Hold ALT + Turn SYNTH knob → Adjust amp MID Hold ALT + Turn DIST knob → Adjust amp BASS Hold ALT + Turn MOD DELAY knob → Adjust amp TREBLE Hold ALT + Turn AMP encoder → Adjust amp CH VOL (Channel Volume) Master Volume & Hi-Mid/Additional Parameters Hold ALT + Hold TAP + Turn DIST knob → Adjust Master Volume Hold ALT + Hold TAP + Turn MOD DELAY knob → Adjust Hi-Mid parameter For Grit amp: Adjusts Midrange Frequency (220 Hz, 800 Hz, or 3000 Hz) For Vintage amp: Adjusts Bright switch (On/Off) For Studio amp: Adjusts Midrange Frequency (150 Hz to 1000 Hz) Cab Selection Hold ALT + Hold TAP + Turn AMP encoder → Select/change Cab model Noise Gate Parameters Hold ALT + Hold TAP + Turn COMP knob → Adjust Gate Threshold Hold ALT + Hold TAP + Turn SYNTH knob → Adjust Gate Decay Preset Functions Press & Hold AMP encoder → Enter Save mode Press & Hold ON + TAP switches → Enter Preset Mode (scroll through presets) Press & Hold both switches (while in Preset Mode) → Exit Preset Mode Global Settings Hold ALT + Press AMP encoder → Enter Global Settings Press ALT (while in Global Settings) → Toggle between Settings pages 1 and 2 Other Functions Hold TAP switch (1 second) → Enter Tuner mode Hold ALT button (3 seconds) → Check remaining battery life Hold ON + TAP (while powering on) → Factory Reset I don't think I know the difference between Master Volume (Alt-Tap-Dist), Channel Volume, and the thumb wheel on the size. Quote Link to comment Share on other sites More sharing options...
