jamesharwood371 Posted December 12, 2025 Share Posted December 12, 2025 I’ve been experimenting with different Line 6 gear and presets, but I’m still struggling to dial in a tone that feels both modern and clear—especially for layered guitar parts. Some presets sound great at low volume but get muddy when I turn up, while others cut through the mix but lose warmth EZPassME login For those of you who’ve mastered your Line 6 setups (AMPLIFi, Helix, POD Go, etc.), what specific approaches or settings helped you achieve a balanced, articulate tone? Do you start with factory presets or build from scratch? Any EQ or cab/IR tips that made a big difference? How do you keep high‑gain tones tight without sounding harsh? I’d love to hear your workflow, favorite tricks, or even example settings that helped you get the sound you wanted. Quote Link to comment Share on other sites More sharing options...
bbehrens Posted January 5 Share Posted January 5 I often just take any old preset that I like or is similar to what I am looking for. However, I also have a spreadsheet and some scripts that can scour all of my Line 6 Helix presets and pull out any block in any preset and I put these into Excel spreadsheets so I can quickly look at what presets use which Amp models or IR's or Distortion pedals, etc. But if I am after clarity or a specific tone then I will follow Jason Sadites advice and just start with an Amp and a Cab. I will often put a one switch looper in front of everything so that I can play a chord progression, lead part or ambient part so that I can just swap through Amps or Cabs or effects or whatever. While Line 6 has provided MANY preset examples that are widely varied, many of the presets that you can buy online often have the same Amp/Cabs and effects chains for certain styles of music. Jason Sadites is vocal about his use of Compressors, EQ, and ribbon mics. Steve Sterlacci, primarily just uses his Helix as a simple pedal board. Worship Tutorials often uses the same Amp/Cab and effects chains in many different songs. What I think that they have in common is that you can get the best sound from focusing on the basics. Oh, and I would highly recommend any of their presets. I just wish that they were a little cheaper is all. If you are layering parts, then start with a basic tone and don't go too far beyond that until you start layering. Do not add too much early on. That will give you an idea of how the different guitar parts interact with each other. You might also use the looper to get multiple parts once you start building your preset. Add EQ, Compression, and other transparent effects earlier and then add Delays and Reverbs later. This will help clarify what you are listening to. To keep Hi-Gain tones tight, keep it clean. Angus Clark from Trans-Siberian Orchestra is VERY open about his guitar, effects, and playing style. He will even walk you through how he plays some of those famous TSO songs. His tone is cleaner than most people come up with. Often, Distortion, Reverb, and Delay can be used to cover up sloppy playing (which is not a bad thing). But you have to play it cleanly enough to not rely on those things that can muddy up your sound. Hope this was helpful. Just 2 cents. Quote Link to comment Share on other sites More sharing options...
