TimAndSmith Posted December 17, 2025 Share Posted December 17, 2025 I'm having an issue with assigned controllers and snapshots. In Helix floor I often assigned some controls to a foot switch like an amp gain boost or raising reverb mix and time. Helix would treat that button just like a stomp switch. If I had the controller on and saved it to a snapshot it would be on. Both the parameter and the state of the button would change with the snapshot. Now, in Stadium, if I save the controller/button in a snapshot, the parameters change but the state of the button does not change. I.E. if the button is a reverb boost, the snapshot saves the parameters for the boost, but the button does not turn on/off with the parameter change. I have flipped the switch for "Snapshot Ctrl" in the saved parameter so that's not it. Am I missing a setting somewhere or does Stadium just not work this way at this point? It's not the end of the world if this won't work with Stadium but it's real nice to be able to see the state of an effect or setting by the on/off light on the foot switch as you move through snapshots. Quote Link to comment Share on other sites More sharing options...
gbr13697 Posted December 19, 2025 Share Posted December 19, 2025 I concur that the interaction between footswitch assignments and snapshots is a bit hit and miss in the Stadium at the moment. Many of my presets that I imported from Helix Floor have had unwanted Snapshot Bypass control and Snapshot Control of parameters added to them, in addition to the footswitch or expression pedal controllers that were there originally. This double-up of controls for the same parameters has been causing me no end of problems, and it is taking an age to go through all the presets and get rid of all the unwanted snapshot controls. The on/off status of the ring lights around the footswitch is also inconsistent. Have you tried activating the snapshot in question, and then also pressing the footswitch to check what happens to the parameters and the ring light? It may just be that the footswitch status is reversed. Quote Link to comment Share on other sites More sharing options...
TimAndSmith Posted December 20, 2025 Author Share Posted December 20, 2025 I have definitely tried all the combinations of snapshots and footswitch combinations. It's not a status reversal. Snapshots just doesn't seem to control the LED status like it used to. I can work around it and hopefully it will be addressed in a future update. Also hoping for a global setting where you can set default status on snapshot bypass control rather than everything defaulting to on. There are definitely more "bugs" and basic functionality missing that I was expecting with Stadium but the sounds and hardware are AMAZING! The rest will come in time I suspect. Quote Link to comment Share on other sites More sharing options...
