4-cable method and tuner mute
sagardam
Hi All
I just got a HX-one and am using it in 4-cable method. I've noticed that when using it in this configuration, the tuner mute seems to only mute the final output of the HX (i.e. the signal is still output to the "loop" even when in tuner mute mode, despite the manual stating that when tuner audio setting is selected to "mute" that "all output is muted").
Is there a way around this? And/or could the next firmware update include a fix or option here so that all output (final output and the loop) is muted when tuner mute is active?
For context - I'm using it in an FX chain with multiple DI/signal takeoff points within the chain, and would appreciate if hte tuner muted everything (at the moment, if I have a DI in the loop then this signal won't be muted when I step on the tuner).
