Possible to use amp model instead of distortion pedal model while connected to Fender Deluxe Reverb ?
jpdesroc
I'm about to buy a Helix Stadium XL floor board and want to use it
mainly LIVE directly connected to my 1973 Fender Deluxe Reverb combo amp.
Is-it possible to use amp model instead of distortion pedal models while directly connected to 1973 Fender Deluxe Reverb ?
Remember, the Fender Deluxe Reverb has no SEND/RETURN connections.
I was thinking to choose an amp model without any cab on the stream line
in replacement of a distortion pedal model for my LIVE presets.
What do you think ?
Of course its possible, desirable - that is a matter of taste. You're not thinking amp models output amp to speaker level signal are you, hence your concerns?
You can put anything in the modelling world in front of an amp, and manage its level to suit. Thats kind of the beauty of it.
Whether it works, only you can say.
Running a modeller in front of an amp is not a good way to do things.  The point of the modeller is to give you many different sounds. When placed in front of an amp, the amps input frequency response will drastically color the sound. You will drastically reduce the variety of sounds you can get.
As Waymda said, you CAN do it. And you may even like it. But dont expect a variety of great sounds unless your amp is super clean and does not have a drastic EQ curve.
In theory, you would want to run PreAmps only and use the amplifier as the power amp. You may want to reduce amp settings like Sag, etc which are power amp things.
Another reason not to use an amp is that the speaker itself will color the sound. Most people use an FRFR, cheap PA speaker, etc to get a very flat frequency response. This lets you get the most variety in the modeller.
I do not have a Stadium yet. Older Line 6 models let you adjust the output to try and match what type of amplifier you are using. So you can try to overcome the amps EQ.
