Frankpc Posted Wednesday at 03:11 PM Share Posted Wednesday at 03:11 PM On my POD HD Pro X with firmware version 2.62, I have "Input 1 Source" set to "Guitar" and "Input 2 Source" set to "Mic". I would like to keep the effects for the guitar as they are but the same effects are being applied to the microphone. How can I keep the microphone effects separate or off so I can use the microphone for vocals? It seems the "Inputs Setup" is the key. The options are "Preset" and "Global". But I cannot figure out how those function. The POD would have to accept two separate signal chains. My POD HD Pro X Edit version is 2.27.0 Is it even possible to prevent the microphone output from being affected by the guitar effects? Thank you! Quote Link to comment Share on other sites More sharing options...
hurghanico Posted 18 hours ago Share Posted 18 hours ago Move all the blocks amp/fx for guitar in path A. ie by using the editor drag and drop them into the upper line (path A) just after the initial pre-split path. Do the same thing for the fx you need for the voice but drag and drop them into the lower line (path B). Doing so your guitar chain and voice chain will be independent and separate. 1 Quote Link to comment Share on other sites More sharing options...
Frankpc Posted 17 hours ago Author Share Posted 17 hours ago Thank you! That works. Quote Link to comment Share on other sites More sharing options...
