A/B Switch Footswitch Assignment - LED Not Updating Between Snapshots
brtd90
I have a footswitch assigned to be an A/B Switcher to change between amps, and the LED is on when routing to Path B. However, if I route to path B on my current Snapshot, and toggle to another Snapshot that is set to Path A, then the LED doesn't update and stays lit. The opposite is true as well (and every combination I can think of).
The footswitch function still works, so if you press it once it toggles to Path B, and the LED will self correct. Really this is just the visual queue of which amp I have active on a given snapshot is not really functioning. (Currently trying to not utilize snapshots to change between amps).
Not sure if this a bug, a feature suggestion, or I am just missing something. But appreciate any help
