jpdesroc Posted July 3 Share Posted July 3 I have a preset that uses a Wha in the block line. If I'm in a snapshot, then engage the wah, play with it, then change my snapshot for another the Wah get stuck at the position the pedal was when I changed the snapshot (?) If I go back to my preceding snapshot the Wah resume workin from where it was before the snapshot change.. What could I do to keep the Wah 'sweling' movement alive when changing snapshots ? The Wah Snapshots Set Bypass switch parameter is at OFF position. On all my snapshots the saved setting is: Volume pedal ON (showing on right controler BLUE LED) Then when activeted the Wah is showing on left controler RED LED. So what happens is that when I engage the Wah the left controler RED LED lits up. But when I change snapshots, because they are all programed idle with Volume pedal ON (showing on right controler BLUE LED) it changes to this VOL setup --> but with the Wah last position sound ! Pushing the Wah pedal to change to left RED light it then goes to Vol sound but stuck itself too to a Vol position ! Hmmm.. There are no ext pedal controler connected. Only the internal Vol/Wah standard switching used. Quote Link to comment Share on other sites More sharing options...
