henricus1180 Posted August 21 Share Posted August 21 The Stadium manual implies that the ASIO Settings in the DAW should allow buffer size to be selected. I'm using Ableton (in Windows) and the Stadium ASIO settings in there show the buffer fixed at 64, with no option to change it. This is fine for recording, but it might be good to be able to increase it for playback where latency is less significant. Is this just Ableton, or is the Stadium manual misleading? Quote Link to comment Share on other sites More sharing options...
henricus1180 Posted 19 minutes ago Author Share Posted 19 minutes ago Not sure if this was there all the time, but I noticed a Hardware Setup button in the ASIO settings. When you press this, you get another dialog containing a Buffer Size dropdown. Initially, this didn't seem to be doing anything, as the selected value in the dropdown was 48, but the main Audio Settings were still showing 64. However, when I increased it to 96, the Ableton value changed to 128, and the same happens with other values in the list: - 48 -> 64 - 64 -> 64 - 96 -> 128 - 128 -> 128 - 192 -> 256 - 256 -> 256 ...and so on. Although Ableton doesn't show equivalents for all of them, they do have an effect as the Input and Output latency changes for each value in the dropdown. Quote Link to comment Share on other sites More sharing options...
