Ramping between two parameter values with MIDI on the HX Effects
Hypnonaut89
Hello
When sending CC MIDI messages to the HX Effects to control a parameter's value, is it possible to have a ramping effect before the target value is reached? The obvious use case I'm thinking of is to use an external MIDI switch to toggle between the min and max values of a delay's feedback, but it would be better and sound more natural if the change from one value to another was progressive, like using an expression pedal. Is this an available feature in the HX Effects?
Thanks for your help
