sacredbeast Posted June 24, 2014 Share Posted June 24, 2014 Hi, I have owned my M13 for a month or so now. Its an awesome piece of gear over all but after a few weeks of owning it the TAP button doesn't seem to change tempo and when i hold it in to get to the tuner it doesn't work at all. Pretty sure the button is defective and dead. Any advice or trouble shooting somebody could recommend to me. Everything is plugged in the way it should be. It worked at one point.. = ( Thanks, Alex / Sacredbeast. Quote Link to comment Share on other sites More sharing options...
JTSC777 Posted June 25, 2014 Share Posted June 25, 2014 If it's new take it back to the retailer and get another. If it is used as mine is I had the same problem. That switch gets used a lot as it is also the tuner access and tap tempo. I opened my unit and replaced the tiny switch under the plunger/footswitch. This is not easy to do and I recommend you have a friend with soldering electronic skills help you or take it to a repair shop. Cleaning it might help and you can squirt a little contact cleaner down into it and gently work it a few times and see if that helps. Good Luck! Quote Link to comment Share on other sites More sharing options...
sacredbeast Posted June 26, 2014 Author Share Posted June 26, 2014 Thank you for the response. There is a Line 6 service center near my home luckily. Will be bringing it in for repair. Thanks again, Alex Quote Link to comment Share on other sites More sharing options...
iwanandringa Posted April 29, 2017 Share Posted April 29, 2017 I got to this thread after experiencing same issue, just a couple of weeks in use and just right after having done latest 221 fw update got the problem the switch either doesnt react, gets into tuner mode but pops back to normal mode upon release or taking a very long time before switch is made. I twisted/turned the know around a few rounds and it seemed to be gone. Let's see what's next.. Quote Link to comment Share on other sites More sharing options...
JTSC777 Posted May 21, 2017 Share Posted May 21, 2017 I got to this thread after experiencing same issue, just a couple of weeks in use and just right after having done latest 221 fw update got the problem the switch either doesnt react, gets into tuner mode but pops back to normal mode upon release or taking a very long time before switch is made. I twisted/turned the know around a few rounds and it seemed to be gone. Let's see what's next.. you will need to replace the switch. Quote Link to comment Share on other sites More sharing options...
