Line 6 Spider Classic 15 watt guitar amp with amp and effects modeling for practicing and jamming
Line 6 effects processors are designed to be integrated into traditional amp and pedal setups—putting a wide variety of classic and modern effects literally at your feet. From the exceptionally powerful and versatile HX Effects to the workhorse M5® to the instantly iconic DL4 MkII delay and looping pedal—there is a Line 6 effects processor to meet your needs.
Explore Features
  • BUILD
  • INTERACTION
  • ANALOG BYPASS
  • FOOTSWITCHES
  • TUNER
  • EXPRESSION PEDAL
  • I/O LEVEL SHIFTING
  • STEREO INPUTS/STEREO OUTPUTS
  • MIDI
  • LOOPING
  • TAP TEMPO
HX Effects
Learn More
The HX Effects processor was designed to be integrated into traditional amp and pedal setups and may serve as anything from a dedicated multi-effects unit to the command center for an entire rig. Although compact in size, it delivers the same professional-grade sound quality and HX technology found in our market-leading Helix® processors.
DL4 MkII
Learn More
The compact DL4 MkII includes all the sounds and functionality of the original DL4, plus 15 new MkII delays, two loopers, a microphone input, MIDI capabilities, and microSD memory expansion.
The M5 effects processor puts a wide variety of classic and modern effects at your feet.
HX Messenger Bag
A custom-fitted carrying bag specially designed for the HX family of instrument processors.
EX-1 Expression Pedal
Compatible with all Line 6 effects processors and most other Line 6 products.
