Carlos_Danger
Members-
33 -
Everything posted by Carlos_Danger
Disregard. Found the solution. Deauthorize old installations.
Helix Native no longer displays the correct graphics. I tried reinstalling. Now it just shows this:
Helix Native Sounds Way Better Than HX Stomp
Carlos_Danger replied to Carlos_Danger's topic in Helix
Follow up.... Headrush tweeter is not working. On a hunch, I opened the grill of my Headrush 108 and played and listened to the speakers. The tweeter is not working. It must have been intermittent at one point because I remember one day the rig sounded amazing and the next day it was trash. One day I tested the Headrush against the Powercab to see if the Headrush was broken. They sounded the same until i accidentally put switched the powercab from FR to a speaker model. It sounded great. Mulling this over, I realized the Powercab speaker model included the tweeter. Looked into tweeter issues with the Headrush and found that mine is broken. Answering the obvious, why am I using the Headrush when I have a Powercab? I have a small office and apiece of furniture that perfectly fits the Headrush and the HX Stomp. I spend most of my time in here and wanted a compact solution. The Powercab was too big for the room. -
Update: Sorry to have disappeared. My daily driver laptop died. I had to replace it and attend some meetings and get some work done. After looking at this from every angle, I decided perhaps my problem wasn't the HX Stomp, or the Headrush 108. I figured the Headrush was simply oversized for this room, and decided to try something different. I got some small monitors; Presonus Eris 3.5. Problem solved. Through these, I get all the high end content I expect and the amp models sound like they should. I don't know the theory behind all this, but the Headrush really wanted to be louder. The HX Stomp still pushes more bass than Helix Native through Xsonic Interface into the same speakers, but is isn't causing the drowning effect through the Presonus monitors like I was having with the Headrush. I can dial that out now. So maybe it was a perfect storm of the Headrush only opening up at a volume I didn't want in this room. All I can say is I am pretty damn happy now. -
Will report back after I try this. -
I don't know how to do all this. -
I actually turn the input level way down in Helix Native because it distorts otherwise. It also distorts with other PC based amp models like Blackstar St James. Have to turn the input on that down too. Edit: I just tried everything I could. Set the input to the HX Stomp to Line, Guitar Pad ON, Put a gain block on at the front of the chain set to -12db. No success. The only way to describe it is: In Helix Native on a clean preset like Double Vib, If I run my fingernail across the strings I can hear the nail. Can't hear it on the HX Stomp. This guitar has slight fret buzz, I can hear it come through on Helix Native. Can't hear it on the HX Stomp. The upper detail is just gone. -
Just did a blind listening test with THE WIFE. I just played the two and asked her what she heard and how she would describe it. She preferred the Helix Native and said it sounded like there was a blanket over the speaker when I played the HX Stomp. She would be the first to tell me I'm crazy and she doesn't hear it. It is just missing high harmonic content. -
I am going to check the cable from the Stomp to the HR-108. That's the only thing I didn't check yesterday. Forgot to add, the Stomp sounds great through the headphones. This was why I thought it was the HR-108. Then when I tried the Powercab, it still sounded bad. I will do a factory reset because why not. If it doesn't resolve it, I will open a repair ticket. -
Thanks Schmalle. I guess my HX Stomp is defective, because it is dull compared to Helix Native. I will try your suggestions, but I have had the Stomp for a long time, and I know the settings pretty well. It simply sounds muted. -
I checked the Input Z. Made sure it was 1M Ohm to match the Xsonic. I will try the HX Stomp is the interface. Honestly I have been struggling thinking the Headrush was dark. Adding EQ to every patch in the HX Stomp. Was shocked to find that the Headrush was just fine with Helix Native. The Headrush is a tad boomy, but the HX Stomp has muted highs. It is the same through the Powercab. There is something missing through MY HX Stomp. I just want to know if the Stomp is just darker. Is it darker than a full Helix? Full story is, I want to use the HX Stomp as my upstairs office rig. I have a perfect end table that fits the Headrush inside perfectly. The HX Stomp is just uninspiring and dull. Been dialing in presets for years and it just isn't right. Helix Native and the full Helix I tried in GC sounds so good and makes me want to play. I think my Stomp is either defective or it is simply darker. -
The Headrush manual says line level, so I set the HX Stomp accordingly. The Helix Native is going in whatever is coming out of the Xsonic. I experimented switching between line and instrument level out. No bueno. -
Global EQ is off -
I've been struggling with my HX Stomp. It just lacks high end content. I thought it was the Headrush 108 FRFR, and I have been adding EQ to every preset to compensate. Today I connected the Headrush 108 to Helix Native. Bare bones preset with just an amp and cab. It sounds great. All the high end sparkle I was lacking. I played the same preset in the HX Stomp and it just sounds dull and overly bassy. Guitar > Xsonix Xtone > Helix Native > Headrush 108 vs Guitar > HX Stomp > Headrush 108 I don't get it. Is this just how it is, or could my HX Stomp be defective.
HX Stomp - Hotone Expression Pedal I just learned the awesome feature that you can control multiple parameters with one expression pedal. This is incredible! However... Cali IV Lead - I am setting up a rhythm to lead patch where the expression pedal steps multiple parameters up to screaming solo territory. This works, except for Lead Drive. Lead Gain goes up and down according to the pedal position. Lead Drive won't go higher than 5.5 regardless of where I set the max. I want it to go up to 8. I can't figure out why all other parameters work when set to the expression pedal, Lead Drive won't. Any suggestions?
FIXED! FS4 is assigned to the tuner by default. Changed FS4 to Stomp 4 and it works now. Leaving this here in case anyone else goes through this.
I have a weird problem with my Midi Baby 3 & HX Stomp. I can assign all footswitches except FS4 For instance the Right switch is set up as follows to trigger FS5: 1: CC Toggle - Channel 1 - Send CC53 - value 127 It works If I change it to Send CC52, FS4 does not trigger. I have pedals assigned to FS1 through FS5 and can get all of them to work but not FS4. I have tried it on all button positions, I can't get the Midi Baby to trigger FS4. Perhaps there is a setting on the Stomp that I have missed. Anyone solve this?
Tried to update my Amplifi 150 via USB. When trying to put it into pairing mode, I hold down Tap and Tone while turning on. All it does is go "POP" and fail to start. So, I am attempting to update to 2.0 using bluetooth and my Ipad Hope this works. Not happy that my amp pairing mode doesn't work.
I don't believe this is an issue of the one that "squeaked through". My 150 didn't rattle out of the box, but once it did it got worse. Before I fixed it, the amp was rattling at 30%. When I was considering returning it, the other 150 at a different GC also rattled. Looks like a design flaw to me.
I agree. Exactly how could they miss this?
FIXED I found the source of my problem. I took off the back panel and noticed that the metal wrap around grill is vibrating against the frame under the back plate. I fixed most of the vibration by jamming pics between the frame and the edges of the grill. The long-term fix will be to install adhesive gasket tape under the edge of the grill. I can either wedge the gasket under the grill or completely disassemble the amp. I know complete disassembly is the proper way, but cracking this puzzle box gives me nightmares. I am afraid of causing more problems. ***Adding on for visibility purposes*** We are aware of the reports of the AMPLIFi’s back panel vibrating under certain conditions. Although we have not found this to be the experience of all who use the amp, we take the reports seriously and are actively working on diagnosing the root cause and finding a solution. We will update the community as pertinent information is made available to us. We apologize to those who’ve had this experience, and we ask that you remain patient with us as we define and implement the solution. Line 6 Customer Support
I am nearing my 30 day mark. I am leaning towards keeping it because I really like it as a low volume practice thing. Hate the vibration and I know I will eventually loathe this amp over it. Sigh...so close...
I went to GC and played a new one and it had the same issue. I am really torn because I really like this thing. The jury is still out.
I am going to bring it back and get a non vibrating one
I am getting real bad resonance vibration sounds from the chassis of my Amplifi 150. When I hit certain notes, it sounds like there is a maraca in my amp. This is driving me crazy. This amp may have to go back to GC.
