Wah-bisca
Product Management
    7
Everything posted by Wah-bisca
  1. Hey, Fody80! Could you tell us a little more about your setup? The quality/speed of your USB-C cable might be the issue. I am not experiencing any playback issues (Logic, Youtube on Chrome Browser, and Spotify app) on my Mac mini, or macbook pro with the USB-C cable that comes standard with the macbook pro for charging. I believe it is USB 2 (2 meters). Are you running at 48kHz?
  2. Hey Glideman! Do you mean that you can't update via USB with the editor, or that you cannot edit using the editor when connected USB? Editing tethered w/USB isn't implemented at this time, but will be in a future build.
  3. @ftmusic1 I am on Tahoe 26.0 and not experiencing the crash you described with importing presets/setlists or copy/paste items such as blocks in the signal flow and presets in the Librarian. Can you provide more details about your setup? Are you using a USB-C adaptor? If so, have you tried a different one?
  4. Hi all! This is a result of too many authorizations on your Line 6 account. Login to your Line 6 account and go to Authorized Devices and Deauthorize computers you no longer use. Sometimes a system will be updated and after signing into Native/HX Edit will register as a new device. For example: You originally had Ventura OS and you authorized Native. Later, Sonoma comes out and you upgrade, or perhaps you swapped out your hard drive... There are many reasons for this happening. Perhaps you got a new computer. Perhaps you signed into Native with your work computer... If you were to look at your account's "Authorized Devices" you should Deauthorize any computers that you no longer use. Navigate to Authorized Devices @line6.com (it is under your sign-in avatar) and locate the Deauthorize button next to the Authorized date to remove any unwanted devices. Hope this helps...
  5. Hey standish33, I've experienced this a number of times over the years on various installs... If restarting and reinstalling doesn't work, you can try what is suggested in the following link https://appuals.com/error-opening-file-for-writing/#:~:text=You might be seeing the,written by your user account. Hope this helps... George
  6. Hello! Just wanted to verify your DAW and system for QA. I have looked at the Doom plugin and cannot reproduce what you have described. Testing the parameters I noticed with a sine wave that a higher octave is present when adjusting the octave parameter- similar to that of a proctavia, and with pink/white noise the filter seems to to be functioning as a low pass. These parameters may seem more subtle than expected but are functioning on Window 10 [AAX]Pro Tools/[VST]Cubase. Hope this helps! George
