ricoustic101 Posted November 8, 2014 Share Posted November 8, 2014 Greetings, Am having a strange problem with my Variax 600 connection to my POD X3. When I use the special cable to connect, the 600 doesn't work with the X3. This was a problem that was "growing." For a bit, it would cut out and if I wiggled the cable it would connect back up. Now it doesn't connect even with a wiggle. The strangeness of this comes from this: Using the same 600 and same cable, if I connect it to my old XT LIve, it works perfectly with no problems. Any ideas???? Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted November 8, 2014 Share Posted November 8, 2014 Sounds like a bad connector. Look closely at the pins and see if they are straight and undamaged. (Both Variax and Pod ends) But it's most likely the Pod end if it works on a different pod. Quote Link to comment Share on other sites More sharing options...
