hd500 to mixer
dazzer20
1) a single normal 1/4 jack cable (for a mixed to mono chain signal)
2) two 1/4 jack cables (one for the stereo Left side and one for the Right one)
3) two XLR balanced cables (same results of point 2 above, good solution for long distance connections)
On the mixer itself. (assuming your PA setup is setup for Stereo)
For 1 use any channel. using a Line In plug.
For 2 you can use two difference channels and pan one hard left and one hard right. Or use a stereo channel on the mixer, IMO the best solution if you have a available stereo channel available and cord length is not a problem.
For 3 same use two pre-amped channels running hard left and hard right.
On 2 & 3 the input will be rather hot so careful not to overdrive the preamps.
