guitarbruno Posted November 22, 2014 Share Posted November 22, 2014 Hi everyone, I own a Pod 2.0, last generation. I've ordered a cable to connect Midi plugs to USB My OS is Vista. Impossible to connect it, in spite of installing last version of Java, USB device (USB 2.0 is the one) is recognized by my system when I plug it. Line 6 Edit doesnt run! However, I've installed last version too. It displays a ? on the detected device. Any ideas? Thx to reply. Bruno Quote Link to comment Share on other sites More sharing options...
BillBee Posted November 22, 2014 Share Posted November 22, 2014 If Line 6 Edit is running and you go into (IIRC) one of the tabs at the top and select the mdi ins and outs and it still doesn't see the Pod. Then it may be your midi/usb cable. If you got a $3 special they usually don't work well - I would suggest you try the M-Audio Uno (be sure to get the lastest drivers for it too). That usually makes things work with L6 Edit. -B Quote Link to comment Share on other sites More sharing options...
guitarbruno Posted November 23, 2014 Author Share Posted November 23, 2014 Hi, thx a lot to reply! :) I've ever seen this proposition, and it seems to be a comfirmation .... Regards. ;) Quote Link to comment Share on other sites More sharing options...
