jegtar Posted November 25, 2014 Share Posted November 25, 2014 I love my 2.0 and always come back to its ease of use. I travel a lot and would like to have an mp3 input without the need for a mixer. I'm handy with a solder, does anyone know an aux input would go on the motherboard? Or does anyone have schematics or internal pics so i could compare an XT and XT live? Quote Link to comment Share on other sites More sharing options...
MiroslavKloud Posted June 4, 2016 Share Posted June 4, 2016 Hello, I am writing late, but hopefully it will be helpful for someone.This AUX works only with the headphone output. (It does not work with LINE OUT). OUTPUT LEVEL does not affect the input volume AUX IN.AUX IN jack also functions as a stereo output. If you do not drill a hole in POD 2.0 can alternatively use a MIDI socket (see figure). 1 Quote Link to comment Share on other sites More sharing options...
tarahall Posted September 11, 2016 Share Posted September 11, 2016 Hello, I am writing late, but hopefully it will be helpful for someone. This AUX works only with the headphone output. (It does not work with LINE OUT). OUTPUT LEVEL does not affect the input volume AUX IN. AUX IN jack also functions as a stereo output. If you do not drill a hole in POD 2.0 can alternatively use a MIDI socket (see figure). R92 & R94 are for the POD 2.0. Do you know what the equivalents are for the POD XT? I wanted to patch in an FX Loop or AUX Send & Return into my POD XT after the guitar input and feed it back in before the output without using any of the built in digital effects. Has anyone done this and/or are there any schematics for the POD XT anywhere? Quote Link to comment Share on other sites More sharing options...
yankazaz Posted April 19, 2017 Share Posted April 19, 2017 Hello, I am writing late, but hopefully it will be helpful for someone. This AUX works only with the headphone output. (It does not work with LINE OUT). OUTPUT LEVEL does not affect the input volume AUX IN. AUX IN jack also functions as a stereo output. If you do not drill a hole in POD 2.0 can alternatively use a MIDI socket (see figure). Hi, Can you specify the MIDI pin, that could be for AUX in mods? Thank you! Quote Link to comment Share on other sites More sharing options...
hobotek Posted April 21, 2018 Share Posted April 21, 2018 On 6/4/2016 at 2:44 PM, MiroslavKloud said: Hello, I am writing late, but hopefully it will be helpful for someone. This AUX works only with the headphone output. (It does not work with LINE OUT). OUTPUT LEVEL does not affect the input volume AUX IN. AUX IN jack also functions as a stereo output. If you do not drill a hole in POD 2.0 can alternatively use a MIDI socket (see figure). Thanks brother, you da man. Exactly what I was looking for. Quote Link to comment Share on other sites More sharing options...
MiroslavKloud Posted April 21, 2018 Share Posted April 21, 2018 On 19. 4. 2017 at 6:19 AM, yankazaz said: Hi, Can you specify the MIDI pin, that could be for AUX in mods? Thank you! Hi, I think that the image is sufficiently accurate. 1 and 3 - signal, 2 - GND. Quote Link to comment Share on other sites More sharing options...
